Subs not hitting hard with new amp
LordSauron775
Awhile back I posted asking which amp I should use for my 2 12 kicker comps. I decided to get a kenwood kac-2404s. I hooked it up and had an audio friend tune it but for someone reason it doesn't hit as hard as my sony xplode 600watt. Can anyone tell me what could be causing it to not hit as hard?
Why did you get a 4 channel amp for subs? I mean, you can use it like that, but thats pretty odd.
x2. 4 channels are NOT to be used with woofers.
also, even though the sony amp isnt doing rated either, that 4 chan amp is less power than the sony most likely. that 4 chan is probably 40 or less rms per chan, even if you bridged two channels, youd be giving maybe 75 rms to each sub, that would be the reason they arent hitting hard as you said. granted the sony probably isnt much more power overall compared to the 4 chan, you are still giving the subs less power with the kenwood, especially if you only have each sub wired to one chan
Thanks I guess I'll have to take it back and look for a better one
when i had kicker comps, i ran them on a rockford fosgate prime 500 amp, they sounded nice. i think those are rated at 250 or 300 rms each, so you re going to want to get an amp to match that. if you are going to run them at 4 ohms, then you would want an amp that can put out around 500 watts or so at 4 ohms. if you re going to run them at 1 ohm, you need to find an amp that is one ohm stable and can put out the power you want at 1 ohm. the enclosure also plays role in it, but someone else is better suited to explain that. best thing to do if you want advice for good mp to use with those subs, is list what you have, such as electrical, subs, enclosure (volume, type, tuning if known), and people will help you out for sure. look around hereon the forum or do more research before making a decision to buy
did somebody tell you to get that amp?
what model number woofers do you have
  • 4-channel car amplifier
  • 40 watts RMS x 4 at 4 ohms (60 watts x 4 at 2 ohms)
  • 130 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
  • CEA-2006 compliant
  • switchable high-pass filter (80 Hz, 12 dB per octave) on front (A ch) channels
  • variable low-pass filter (50-200 Hz, 18 dB per octave) on rear (B ch) channels
  • MOSFET power supply
  • preamp and speaker-level inputs
  • requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
  • fuse rating: 30A x 1
  • 13-13/16"W x 2-3/8"H x 8-1/2"D
the filters and you probly expected more power from the amp?
03 s-10 owned since 35k now 150k
alpine type-s 6.5 comp
alpine type-e 10 ported fiberglass
jl 300/4 (dead)
jl500/1 (dead)
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
