Mario928 Posted November 30, 2013 Report Posted November 30, 2013 I do not know much about pc. So i really need some help on getting a power supply for my 680 ftw. Right know i have a 620w Antec and everytime i try to overclock my video card by just a notch it turns off after a couple seconds. my budget for power supply is 160. I would like to get a 8g of memory but dont know what will be a good. My budget for memory 80 bucks or could be allitle more. My motherbord is http://www.newegg.com/Product/Product.aspx?Item=N82E16813186177 I would like to get G. Skill since there on sale for black friday Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill
Cameronmyers74 Posted November 30, 2013 Report Posted November 30, 2013 You could use newegg power supply calculator to find out what power supply you need. and what speed do you want for your ram 1333 or 1600?
Mario928 Posted November 30, 2013 Author Report Posted November 30, 2013 The bigger power supply the better for future proof and 1333 speed clock. I dont know much about pc brands so i dont know which brand is good or bad. Is this a good power supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011 850w Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill
Cameronmyers74 Posted November 30, 2013 Report Posted November 30, 2013 Corsair is a very good brand. What you want to look for when buying a power supply is how many and the video card require or what the minimum power supply wattage is for this model its 550 watts http://www.newegg.com/Product/Product.aspx?Item=N82E16814130801 so an 850 should be fine, and allow you room to overclock. And if your motherboard supports DDR3 1600 memory I would just get that here's some g.skill ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Mario928 Posted November 30, 2013 Author Report Posted November 30, 2013 Corsair is a very good brand. What you want to look for when buying a power supply is how many and the video card require or what the minimum power supply wattage is for this model its 550 watts http://www.newegg.com/Product/Product.aspx?Item=N82E16814130801 so an 850 should be fine, and allow you room to overclock. And if your motherboard supports DDR3 1600 memory I would just get that here's some g.skill ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428 Were can i check if my motherboard supports ddr3 1600? Sorry but i am a noob when its comes to computer hardware. Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill
Cameronmyers74 Posted November 30, 2013 Report Posted November 30, 2013 http://www.newegg.com/Product/Product.aspx?Item=N82E16813186177 it does support ddr3 but on 1333 and 1066 so I would get the 1333, thats your mobo you posted in the first post, and just scroll down or click on specifications and then scroll down to were it says memory standard:)
