I need some google sketchup help...
shanesauce
I am designing a box in sketchup and I can't put a subwoofer hole in my panels...
I have watched 20 different videos and googled it but none of the suggestions work...
I am drawing a line from the top of the panel to the bottom, finding then mid point then using the circle tool to make a 11 inch circle.
I click on the face of the circle and try to push/pull but I can't get it to "cut out" the circle.
Someone help before I blow my brains out.
:suicide-santa::suicide-santa::suicide-santa:
- 2012 Mustang 3.7 Manual
- Audio under construction
Did you make your baffle into a group before you tried this?
Builds:
Yes, I even just remade the panel to double check.
The baffle is grouped and I make the circle on the face of the panel then delete the reference lines, I click on the face of the circle then use push/pull to try and remove the circle and it doesn't work.
Is there a certain place I need to put my mouse or another way I can put a hole in a panel?
WOWOWOWOWOW
The problem was that I had the baffle as a group before I made the holes!
2 HOURS OF MY LIFE WASTED.
Thanks again though guys, don't know what I would do without some helpful ears.
  • Who's Online   0 Members, 0 Anonymous, 6164 Guests (See full list)
