FS : Skar Audio SK-4500.1D - $750 Shipped
1. Product:
Skar Audio SK-4500.1D Monoblock Amplifier
2. Specs:
We bring you the flagship amplifier of Skar Audio and the most powerful in the SK Series, the SK-4500.1D. This is the ultimate in a competition grade class D Monoblock and made for only the most serious audiophiles. Featuring massive dual 1/0 gauge Power and Ground Terminals for maximum current transfer, along with a highly efficient heat sink design, you can expect maximum power output from this amplifier due to its ability to keep cool. It doesn't stop there, with the SK-4500.1D being a true competition grade amplifier, it is capable of running on 18V electrical systems at a 1 Ohm load. For a full list of specifications and product features please see the technical spec's below.
Technical Specifications
Class D Digital Monoblock Amplifier
Compeition Grade
Linkable / Strappable
4 Way Protection Circuitry : Thermal, Voltage, Speaker, DC
RMS Power @ 1 Ohm : 4,900 Watts x 1 Channel (14.4v)
RMS Power @ 2 Ohms : 2,780 Watts x 1 Channel (14.4v)
RMS Power @ 4 Ohms : 1,500 Watts x 1 Channel (14.4v)
RMS Power @ 1 Ohm : 5,860 Watts x 1 Channel (16v)
RMS Power @ 1 Ohm : 7,420 Watts x 1 Channel (18v)
Frequency Response : 15~270Hz
Input Sensitivity : 6V~0.2V
Signal to Noise Ratio : 95dB
Damping Factor : 200<
Low Pass Filter : 35Hz~250hz
Subsonic Filter : 10Hz~50Hz
Bass Boost : 0dB~9dB
Phase Shift : 0~180 Degrees
Dual 1/0 Gauge Power and Ground Terminals
Working Voltage : 8.5V~18V
Remote Gain Knob Included
Line Out RCA Connection
Recommended External Fuse Rating (450Amp)
Dimensions : 650mm (Length) x 241mm (Width) x 64.5mm (Height)
3. Description/Condition:
Used but in amazing condition. This was used shortly in a non-abusive setup on (2) Skar Audio ZVX-12's. It works perfect and looks great cosmetically as well. Comes with all original packing! Don't miss out on a rare great price here.
4. Price: :
$750 Shipped via UPS - We will ship to the first payment received for this amp as we anticipate it will sell quickly. Ships same business day and email will be sent with tracking.
PayPal for payment is [email protected]
5. Pictures:
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
