riddler7812 Posted December 4, 2013 Report Posted December 4, 2013 I have a set of soundstream splx-hx 15's in a 13.75 cft box, 120 square port tuned to 32hrtz. They are being powered by 2 powerbass 1500.1's. So here is my question, I was playing the subs the other day and my blazer has a hard cut-off ( the hard pop at power turnoff), and later realized that the plastic cover (retaining ring) protecting the voice coils and spider popped loose on Both of the. Could I use an Epoxy based glue to hold it ir us there a special glue? Also, I contacted Fixmyspeaker.com, and asked for a quote. for $135 per sub, they wil replace the triple spider, flatwoven voice coils,(which it has that now) and direct leads with a psi cone, the rms would be beefed up to 1850 or more by this, which they are 1250 rms now(under rated). Should I fix the sub or send it for the upgrade?
jarrius Posted December 4, 2013 Report Posted December 4, 2013 Fixing is cheaper then upgrading. I would fix the subs for now and save up to upgrade your electrical and amps or what ever ales you need 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
JEFFYBOI Posted April 8, 2014 Report Posted April 8, 2014 Easy fix epoxy the plastic ring back to the basket. same thing happened to me man. its a easy fix. Mine are still going strong "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS
