Desousa93 Posted December 9, 2013 Report Share Posted December 9, 2013 anybody use this processor? or have input on it? or should i get a alpine h100 to use with my IVA W203 DD touchscreen? http://www.sonicelectronix.com/item_60630_Kicker-Front-Row-ZXDSP1-12ZXDSP1.html Product Features Digital Signal Processor SHOCwave bass restoration circuit for deep bass and full frequency response 6-Channels (3 stereo pairs) Total sound stage control with speaker time alignment Clip Limiter eliminates distortion for loudest and clearest sound All the crossovers needed for greater accuracy and control Remote level control included Simulated 5.1 surround sound mimics tone of live performance and is ideal for movies 28-/56-bit, double-precision DSP with 24-bit AD/DA converters Product Specifications: 50 MHz CPU / 28-/56-bit double-precision DSP / 24-bit AD/DA convertersFrequency Response (Hz): 10-22k, +/-0.2dB Signal-to-Noise Ratio: 110dB THD: 0.004% 32-step variable crossovers with 12, 24 or 48dB/octave slopes Front: high-pass 0-500Hz or 0-5kHz (10x switch) Rear: high-pass 0-500Hz Rear: low-pass 50-500Hz or 500-5kHz (10x switch) Sub: subsonic filter 0-80Hz, fixed at 48dB/octave Sub: low-pass 40-160Hz Subwoofer Phase: variable 0-180 degrees KickEQ: variable 0-+15dB at 45Hz, Q=3 SHOCwave: variable bass restoration New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
Desousa93 Posted December 9, 2013 Author Report Share Posted December 9, 2013 or should i get a alpine h100 to use with my IVA W203 DD touchscreen? http://www.sonicelectronix.com/item_13870_Alpine-PXA-H100.html New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
Desousa93 Posted December 10, 2013 Author Report Share Posted December 10, 2013 bumpitty bump bump.... lol 54 views and nothing? New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
Desousa93 Posted December 10, 2013 Author Report Share Posted December 10, 2013 Bump New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
