Skax Posted December 16, 2013 Report Posted December 16, 2013 had a quick question , i have 2 p3 15's 2ohm and a 1500bdcp fosgate amp and i was wondering if i could get them down to a 1ohm independence and how or is 2ohm the only option (best option i have)? if not what would be the best way to wire them 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
youngbass98 Posted December 16, 2013 Report Posted December 16, 2013 Are they dual 2 ohm coils of dual 4 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Skax Posted December 16, 2013 Author Report Posted December 16, 2013 Are they dual 2 ohm coils of dual 4 i beleive dual 2 ohm coils , theres 2 positive and 2 negative sides im not to sure lol but i believe thats what they are im semi new to this stuff 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
youngbass98 Posted December 16, 2013 Report Posted December 16, 2013 You can only have 2 ohms or .5 but will void warranty on t1500 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Skax Posted December 16, 2013 Author Report Posted December 16, 2013 You can only have 2 ohms or .5 but will void warranty on t1500 which one would you recommend? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
youngbass98 Posted December 16, 2013 Report Posted December 16, 2013 2 ohms, otherwise you are pushing close to the peak wattage 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Skax Posted December 16, 2013 Author Report Posted December 16, 2013 2 ohms, otherwise you are pushing close to the peak wattage i beleive they are 1200 watts peak each and there is 2 so would it be ok to do .5 ohms? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
youngbass98 Posted December 16, 2013 Report Posted December 16, 2013 If you run at peak your gunna blow them, and Rockford's aren't stable at .5 soo 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Souldrop Posted December 16, 2013 Report Posted December 16, 2013 If you have a T1500BDCP you may as well run them at 2 ohm. It will power them well. 1997 Lexus ES300 HU - Pioneer MVH 7350 Processor - Helix DSP Front Stage - JBL P660C Mid/high amp - Alpine PDX-F4 Subs - 1 IA Death Penalty 12 Sub Amp - Cactus Sounds PF300.1
Skax Posted December 16, 2013 Author Report Posted December 16, 2013 If you run at peak your gunna blow them, and Rockford's aren't stable at .5 soo ok thanks 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
