Subsonicluv's Side Projects: 2012 F150 under seat enclosures
Glueing down 2nd baffle. It was supposed to be all one piece until I broke it and then it turned into 3 pieces. Still looked good IMO.
Glue dried and rounded over the entire front. Also used a 3/4 roundover bit for port openings.
Nice and recessed
04 Blazer Xtreme
HU: Kenwood KDC-MP235
Front Stage: Lanzar MX6C Components
Rear Stage: Lanzar MX693 6X9's
Sub Stage: (2) Obsidian 18 D2 V2
Mids / Highs Amp: Boston Acoustics GTA 704
Sub Amp: Boston Acoustics GTA 1000m
Optima Yellow Top (up front)
Singer 275A Alternator
Future Plans:
One More GTA 1000m (maybe)
More batteries
More runs of 1/0
Pioneer DEH-X7500S (on order)
Got out of order here. This is one of my favorite pics
Glued and glassed in some 45s directly behind the subs.
Started to resin the rest of the interior.
Resin done, sanded and smoothed out
Undercoat
04 Blazer Xtreme
Future Plans:
More batteries
More runs of 1/0
OK here's where I started to get nervous. Stapled fleece down to about 3/8 to a 1/2" below the top edge. Temp mounted the subs so the magnets could push up the fabric so I could glass around them.
My 1st big glassing job. My friend knew it but he didn't care....He just said go with it and we'll see how it turns out
Subs were protected with plastic and masking tape
1st layers
Subs removed. It was holding shape
More glassing
More sanding
Getting there
Pic my wife took of me slaving away
04 Blazer Xtreme
Future Plans:
More batteries
More runs of 1/0
Did one more coat covering the entire outside
Started sanding all of it smooth
A little bit of body filler and primer
prepping for paint
Wet sanded and terminals drilled. Used 1/4-20 screws. Ended up flipping them around because of clearance issues behind the box
Shitty Krylon paint
Used Rustolium. Much better
04 Blazer Xtreme
Future Plans:
More batteries
More runs of 1/0
Really nice work
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Subs mounted and wired up. put the coils in series and then the subs will be paralleled for a final 2ohm load
So I tested them in my garage with a small stereo receiver. Had to series the subs together to bring them up to 8 ohms.
I didn't sound bad except for a little bit of port noise. I was a little afraid of this because of the 180 degree turn in the ports.
I hoped it wouldn't be audible inside a vehicle and I did some more testing in my blazer. Brought the subs back down to a 2 ohm load and used my Boston Acoustics GTA1000m so they were getting about 500 watts a piece. Maybe less because of rise.
They sounded great! Played down to 27Hz without breaking a sweat.
Here it is in the F150
He's got the 500/1 portion of a JL900/5 on them right now and they're laughing at it. All stock electrical. There is a Hifonics Zeus 3000.1 installed and waiting to be wired up. Hopefully he does some electrical upgrades before.
I'll try to get better pics of it in has truck and maybe some vids of it playing. He's out of town right now so I'll have to wait till he gets back
04 Blazer Xtreme
Future Plans:
More batteries
More runs of 1/0
Really nice work
Thanks!
04 Blazer Xtreme
Future Plans:
More batteries
More runs of 1/0
Absolutely gorgeous work!
Thank you sir!
04 Blazer Xtreme
Future Plans:
More batteries
More runs of 1/0
beautiful boxes man!
2012 Silverado ext cab
Kenwood DDX470
XS D3400 (starter)
XS D375 (under passenger seat)
XS d3100
Mechman 240
Big three
SMD VM-1
All SHCA wire
80 sq feet of Damplifier
6.5 Crescendo CZ's (front doors) (needed)
5..25 Crescendo CZ's (back door) (needed)
Crescendo 125.4 (needed)
Sundown Zv4 12
Skar 4500 (2ohm)
