buzzing from subs
trisdog74
This morning I started my car and this buzzing noise started coming out of my subs. When I accelerate the noise gets louder but goes away most of the time when I put the car in park. I went to the shop about a month ago and its been working fine until today. I took it back to the shop and they told me I need a noise distorter. I wiggled the radio and the noise went away but started up again. Everything in my new car I took it out my old car and it worked just fine in there. Can anybody give me some advice before this shop has its way with me. I have a 1999 regal and the power wire ran from my fuse box. 1000 watt amp 2 pioneers 12 8ohm load
Could your cables be old? You stated you took everything out of your old car to put in your new car, correct? I agree with Noelito, check your grounds and rca! You said, you moved the radio and it stopped so there must be a loose connection or bad cables. Perhaps even a slightly shaved or cut wire that could be in contact with some metal. Good luck!
  • Who's Online   0 Members, 0 Anonymous, 2936 Guests (See full list)
