how to Wire mids and highs
Pedro Rivera
Hi guy's i got 4 6" 1/2 mids and highs 2 6x9 mids highs audio pipe hook up to a SSL 3000 watts 2ch my problem is like 30 min of use it get's hot and trip i have to turn the headunit off and turn it right back on it play an it repeat again does anybody know what i can do to fix this problem and the gain is not even half way need help guy thank you merry Christmas and a happy new year
Your amp is going into protect. How have you got the speakers wired up, might be to low of a load for the amp to handle. The amp itself is also a problem ssl doesn't do nearly what its rated at. What kind of headunit do you have.
if it was me ied sell that amp and get a good 4channel, but if you have to use that i would wire them in series/parallel like this
do you know what series and parallel means? if not
you need to do this with each side of your amp, should give you 6ohm stereo, amp will run at this so no problem
wire the 6x9 like the bottom speaker, and the 6&1/2's like the top 2 and you should be good
and your amp will run cooler, and would be easier on your speakers, hope this helps
just do this on each channel of your amp and you should be good, still would switch to a 4 channel tho .
this is about the only way i know how to show you to wire what you have atm, hope this helps, if you have any questions about the pic just ask
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
The example he gave you is for one side, like the left channel. Then you do the same for the right channel. But gain needs to be set with a meter or o-scope.
truthsayer
Amazon sells both
SMD Distortion Detector and Oscilloscope
truthsayer
  • Who's Online   0 Members, 0 Anonymous, 1081 Guests (See full list)
