Help running PWX 6.5's!?!?
alenv10
Okay i want to run 4 of the crescendo audio pwx 6.5's in my charger..
I was thinking (4) 8 ohm pwx's
2 wired at 4ohm bridged and the other 2 wired at a 4 ohm bridged
on a sound qubed 120-4
so 340 @ 4ohms bridged...
this gives me about 170 rms per speaker, i will lower the gains, but does all that sound right?
never ran speakers off an amp!!
or should i do (4) 4ohm pwx's and run each into a separate channel.
giving them 4 ohm loads each at 120 wrms to each speaker?
is this **RUNNING ACTIVE**??
i also want to run 2 super tweeters but not worrying about that as of now unless you guys can help out with that as well
NOTHING DOWN HERE YET :(
OBSIDIAN FTW
can anybody help out please
by the way i was talking wiring the actual speaker directly into the amp..
OBSIDIAN FTW
To truly run active you will need a crossover before your amplifier. Do no you are not running active. You will be sending lows and highs to a midrange speaker. You need a head unit that has a electronic crossover or an external crossover. NOT a passive crossover like a component speaker set.
  • Who's Online   0 Members, 0 Anonymous, 1555 Guests (See full list)
