I have an 88 mitsubishi migthy max it has a 7" read drop with a 2* wedge for the pinion. Its stock heigth in the front and its on 20" .my tires are getting eatin away i replaced all tie rods amd taken it to get aligned at a shop amd its making it worse. Any solution to this problem?
You have a 7 inch drop in the rear. Are the rear tires wearing or the fronts. It could be your camber, but you dont have any adjustments on the rear of the truck. At least i'm pretty sure you dont. Anytime you lower a car/truck you alter the alighnment and sometimes will never get it back. Its the price to pay to ride low
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
The front tires are wearing out real bad now that i replaced the tie rods. Before when i had my old tie rods i had my camber going out so thats positive camber? Well no that i replaced all those parts i have the tires wearing out from the inner tire the tires were brand new now their almost useless.
I had ran the tires for almost a year with the old tie rods with no Sing of wear and now with the new tie rods it hasnt even been a month with the new tires and there almost all wasted in the inner part.
Could have a fucked up ball joint. You did get it aligned after the tie rod replacement right? And did not do anything else since then to alter the alighnment
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
30Hz.wav no i actually dont have a printout. But yeah unless the guy at the shop didnt put in mind it was lowered.
Matt14 no i replaced everything even my idler arm and ball joint on the right side then did the alignment.
  • Who's Online   0 Members, 0 Anonymous, 1594 Guests (See full list)
