775Tundra Posted January 17, 2014 Report Posted January 17, 2014 Just buy two 150 amp agu fuses. it's a 1500bdcp and a 440.4 so the distribution block has built in fuses so I don't have to fuse them ? That's what I like about rockford distribution blocks. It has the fusing for each amp so it's a d-block/fuse holder in one. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 Just buy two 150 amp agu fuses. it's a 1500bdcp and a 440.4 so the distribution block has built in fuses so I don't have to fuse them ? That's what I like about rockford distribution blocks. It has the fusing for each amp so it's a d-block/fuse holder in one. somone told me I needed a 150 for the 1500bdcp and a 50 for the 440.4 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 Just buy two 150 amp agu fuses. it's a 1500bdcp and a 440.4 so the distribution block has built in fuses so I don't have to fuse them ?That's what I like about rockford distribution blocks. It has the fusing for each amp so it's a d-block/fuse holder in one.somone told me I needed a 150 for the 1500bdcp and a 50 for the 440.4 Then just buy 1 150 agu and 1 50 agu. Or a couple of each. Either way as long as you don't fuse above the wire rating 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 Just buy two 150 amp agu fuses. it's a 1500bdcp and a 440.4 so the distribution block has built in fuses so I don't have to fuse them ?That's what I like about rockford distribution blocks. It has the fusing for each amp so it's a d-block/fuse holder in one.somone told me I needed a 150 for the 1500bdcp and a 50 for the 440.4 Then just buy 1 150 agu and 1 50 agu. Or a couple of each. Either way as long as you don't fuse above the wire rating What's the wire rating on 0awg 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 On 0 gauge 300. For 4 awg it's 150 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 I have a 200 anl under the hood on my 4awg now should I take it out and put a 150 in or just keep it and upgrade to a 300 for when I install my 0awg this weekend 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 If your doing it this week end just wait till you switch it to 0 awg. Then drop in a 300 or keep your 200 in there since with the fusing from the d-block you won't be pulling more than the 200. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 If your doing it this week end just wait till you switch it to 0 awg. Then drop in a 300 or keep your 200 in there since with the fusing from the d-block you won't be pulling more than the 200.so could u give me a nice little list of what I should get and drop it on here for me 300amp anl fuse for under hood the distribution block and what size fuses for the 2 amps ? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 Pm sent. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Guest Posted January 17, 2014 Report Posted January 17, 2014 add up fuse amount for the amps. that will let you know what size to use. if it comes out to like 220, use a 250. or 180 use a 200
