fusing my amps?
Skax
add up fuse amount for the amps. that will let you know what size to use. if it comes out to like 220, use a 250. or 180 use a 200
We'll they said 150 for the 1500bdcp
50 for the 440.4 TMA
So like a 250 amp anl fuse ?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Personally I wouldn't go with an AGU style fuse block, I would find an ANL or Mini ANL fuse block and distribution block.
I would get this fuse block for under the hood and just choose the 250a fuse option
http://www.knukonceptz.com/productDetail.cfm?prodID=FH-20
and this for in the rear to distribute the power accordingly. Choose the 200a fuse and 50a for the other.
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
It doesn't have a option for a 200 what should I do ?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Buy the fuse from sonicelectronix or amazon
so like Kranny said
Add up the fuse amount 150+50=200 so order fuse block with 150 amp and a 50 amp also get a 250 Amp fuse for under hood or will the 200 I have no do fine? I'll have to wait also to put it in since I have 0awg and it pulls 300 and 4 wag pulls only 150 right ?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Why would he fuse above the wire rating???
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
I would get this fuse block for under the hood and just choose the 250a fuse optionhttp://www.knukonceptz.com/productDetail.cfm?prodID=FH-20
and this for in the rear to distribute the power accordingly. Choose the 200a fuse and 50a for the other. http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12
So just go with what u said right?
300 fuse under hood (after I upgrade to 0awg this weekend )
150 fuse 50 fuse for block ? Also would it be wise to upgrade my 440.4 to 4awg since it 8awg ATM?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Yes.
Does your amp have 4 inputs or 8 gauge inputs? If they are 4 awg inputs I would make it 4 awg.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
Yes.
No idea it's a old amp and can't find anything on it
Total Mobile Audio 440.4
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Yes.
Check if the 8 gauge fit snug or if there is room for more wire.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
  • Who's Online   0 Members, 0 Anonymous, 4622 Guests (See full list)
