Skax Posted January 17, 2014 Author Report Posted January 17, 2014 im upgrading to 1/0 AWG CCA so it can handle 250 amps if im reading correctly so 250 amp fuse under hood 200 for the 1500bdcp 50 for the TMA 440.4? 100% correct! That is exactly what you need. now that i even think about it the 440.4 has fuses already in it so what do i do about that haha 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 im upgrading to 1/0 AWG CCA so it can handle 250 amps if im reading correctly so 250 amp fuse under hood 200 for the 1500bdcp 50 for the TMA 440.4? 100% correct! That is exactly what you need. now that i even think about it the 440.4 has fuses already in it so what do i do about that haha Walwalka was right on the rest. Don't worry about the on board fuses. Those protect the internals of the amp. The fusing on the distro block and fuse holders protects the wiring. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 im upgrading to 1/0 AWG CCA so it can handle 250 amps if im reading correctly so 250 amp fuse under hood 200 for the 1500bdcp 50 for the TMA 440.4? 100% correct! That is exactly what you need. now that i even think about it the 440.4 has fuses already in it so what do i do about that haha Walwalka was right on the rest. Don't worry about the on board fuses. Those protect the internals of the amp. The fusing on the distro block and fuse holders protects the wiring. nvm figured out it has a internal one. so 250 under the hood 250 right before the dblock 200 in the block along with a 50 and my wires from dblock to amps? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 im upgrading to 1/0 AWG CCA so it can handle 250 amps if im reading correctly so 250 amp fuse under hood 200 for the 1500bdcp 50 for the TMA 440.4? 100% correct! That is exactly what you need. now that i even think about it the 440.4 has fuses already in it so what do i do about that hahaWalwalka was right on the rest.Don't worry about the on board fuses. Those protect the internals of the amp. The fusing on the distro block and fuse holders protects the wiring. nvm figured out it has a internal one. so 250 under the hood 250 right before the dblock 200 in the block along with a 50 and my wires from dblock to amps? If you are only using the battery under the hood then you don't need the second 250. The only time you will need that fuse is if you had a power source in the back. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 Battery---250fuse--------------------------d-block w/200 and 50-------------amps 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 250 under hood. 250 before dblock Why??? 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Guest Posted January 17, 2014 Report Posted January 17, 2014 becAuse safer than sorry. it's not wrong LOL
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 becAuse safer than sorry. it's not wrong LOL so what ur saying is battery--->250----->250 before dblock----->dblock with no fuses in it------>wires from dblock to amp 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 becAuse safer than sorry. it's not wrong LOL It's pointless. There is already fusing the will block the power source if something happens. The second one would be a waste of money and is only to be used if there was a battery in the back that would be feeding the wire power. No point whatsoever 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
