Guest Posted January 17, 2014 Report Posted January 17, 2014 not really pointless...I should call you One Fuse, like one direction
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 becAuse safer than sorry. it's not wrong LOL It's pointless. There is already fusing the will block the power source if something happens. The second one would be a waste of money and is only to be used if there was a battery in the back that would be feeding the wire power. No point whatsoever Battery---250fuse--------------------------d-block w/200 and 50-------------amps Battery---250fuse-------------------------250fuse------dblock no fuse------amps which one lol 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 Skax. You want to fuse before and after a battery. Since you will only use a front one, only the after applies. By putting a fuse later on down the wire you are not protecting anything. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Guest Posted January 17, 2014 Report Posted January 17, 2014 fuse blocks are like ten bucks. and what if he does want to run a battery in the future? he'd already be set for that
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 not really pointless...I should call you One Fuse, like one direction No. You have the rule of thumb mixed up. You fuse before and after a POWER source. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 fuse blocks are like ten bucks. and what if he does want to run a battery in the future? he'd already be set for that yea true but im on a semi tight budget now i have like 70$ for fuses and dblock 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
walwalka Posted January 17, 2014 Report Posted January 17, 2014 The disto block that I posted has fuses in it, you just have to have the fuse that you actually put in it. 2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Guest Posted January 17, 2014 Report Posted January 17, 2014 then just run one. running three or zero doesn't matter if your wiring is safe
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 so what im looking at now is 250 anl under hood and a fuse block with a 200 and 50 amp fuse ? could u guys link me a nice 250 anl and a nice dblock with a 200 and 50 amp fuse? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
775Tundra Posted January 17, 2014 Report Posted January 17, 2014 The disto block that I posted has fuses in it, you just have to have the fuse that you actually put in it. Thanks Walwalka. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
