Guest Posted January 17, 2014 Report Posted January 17, 2014 partsexpress has wire lug fuseholders for 5.58. item number 263-630
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 partsexpress has wire lug fuseholders for 5.58. item number 263-630 what i think im ganna do is just what u said battery------>250------>250------>dblock------>amp 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 double post sorry 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 could you guys send me a link of a nice 250 amp fuse with a holder i could use and the dblock (with the fuses if i need them) 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
walwalka Posted January 17, 2014 Report Posted January 17, 2014 Distribution block http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12 Choose 50a for both options as you have to buy a 200amp mini anl. Under the hood fuse block http://www.knukonceptz.com/productDetail.cfm?prodID=FH-20 Choose the 250a option. 200 amp fuse http://www.amazon.com/XScorpion-Platinum-Blue-Mini-MIDI/dp/B0059BZEFG I like the knukonceptz for under the hood because it is waterproof. 2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Skax Posted January 17, 2014 Author Report Posted January 17, 2014 Distribution block http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12 Choose 50a for both options as you have to buy a 200amp mini anl. Under the hood fuse block http://www.knukonceptz.com/productDetail.cfm?prodID=FH-20 Choose the 250a option. 200 amp fuse http://www.amazon.com/XScorpion-Platinum-Blue-Mini-MIDI/dp/B0059BZEFG I like the knukonceptz for under the hood because it is waterproof. ok i went ahead and just did 2 fuses anyway never know when ill add a battery like Kranny said and just put it up in the garage order dblock with 2 50 amp fuses and the 200 amp fuse u showed me thanks guys 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Guest Posted January 17, 2014 Report Posted January 17, 2014 knus compression fittings are absolute garbage
walwalka Posted January 17, 2014 Report Posted January 17, 2014 knus compression fittings are absolute garbage In your opinion. 2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
