Be ok with this electrical?
I want to do 2 runs of OFC 4ga to my amp and big 3 in 4ga OFC ... stock alt,battery.
Right now I have 150amp alt(stock) and a 70AH battery(stock) with a run of stinger OFC 4ga HPM in my 2013 sportage.
My equipment is 2-12"SQ hdc3 in 5cuft tuned to 34hz and a brz2400. And I am only seeing drop to 13.4v full tilt at idle from 14.8v.
Seeing that I am still mid 13v full tilt with only one run of 4ga and stock alt,batt. You guy think with one more run of 4ga and big 3 in 4ga I will be ok. Or should I do like big 3 in 0ga cca and add one more battery?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
^ and I will add this question. Amp calls for 250amp fuse. If I'm on 2 runs of 4 ga should I fuse each run with a 150 amp fuse?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
1/0 awg for big 3 and that dont seem to be a bad drop. You could add a second battery but id keep it like that. If anything id swap just the primary battery
2003 silverado TEAM DC
Pioneer Avh 5500
4 DC lvl 5 18s
12 crescendo pwx 6.5s
4 crescendo ft1 tweets
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Skyhigh speaker wires
Smd vm1
2 DC 175.4
DC 10k
What's the rating on your 4 gauge wire?
Pioneer Avh 5500
4 DC lvl 5 18s
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Smd vm1
2 DC 175.4
DC 10k
150 amps
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Then it would be 150 on each run
Pioneer Avh 5500
4 DC lvl 5 18s
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Smd vm1
2 DC 175.4
DC 10k
Starting battery is a 70ah, and only like 4 months old. So I don't think I will be taking that out
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 3129 Guests (See full list)
