sorry noob question but please reply
so when i start my truck my and turn my music up and the subs start hitting they cut in and out but if im driveing for about 5-10 minutes it will be perfect any ideas on what could be happening
I'd say check your ground, make sure it is on bare metal, preferably to the frame if you can. Check all connections are tight, do that twice. Do you have a way to check the voltage at the amp accurately?
Might be a voltage issue, if you can have someone watch the amp to see if it is going into protect or if the power light is going out.
Thats a good start.
Then wait 5-10 minutes. Sounds like a small sacrifice as compared to blowing a pair of 10s or an amp.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
sounds to me like your battery can not cope at first until it gets alittle charge from the alternator, maybe invest in higher amp/h battery?
"Sub-bass sounds are those approximately below 60 Hz and extending downward to include the lowest frequency humans can hear,
typically 20 Hz.
In this range, human hearing is not very sensitive, so sounds in this range tend to be felt more than heard"
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
