Esenbek Aliev Posted January 26, 2014 Report Posted January 26, 2014 Hey guys, hello from Kyrgyzstan I just bought RF 500X1D to replace my old and huge 500.1 amp I was using high level converter to get RCA cables from it but new amp has high level input (little 4 pin connector which I need to buy from Ebay) does it mean, that I can get rid of converter and rca cables and just plug it in and amp will do all the other stuff? So I'll get simple and clean install without all wires since my car is brand new and don't want to replace my HU.
truthsayer Posted January 26, 2014 Report Posted January 26, 2014 yes, and the amp should have came with the speaker connector. truthsayer
Guest Posted January 26, 2014 Report Posted January 26, 2014 yes, and the amp should have came with the speaker connector. yeah it should have came with one.
Wicks Posted January 26, 2014 Report Posted January 26, 2014 Yep, dump the converter, less comports means less problems. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Esenbek Aliev Posted January 26, 2014 Author Report Posted January 26, 2014 Thank you guys This is all it has (specs http://www.rockfordfosgate.com/products/details/r500x1d ) Is it the right one?
Guest Posted January 26, 2014 Report Posted January 26, 2014 the 4 pin square plug on the lower right. did it not come with a little harness plug in the box that fits in there?
Esenbek Aliev Posted January 26, 2014 Author Report Posted January 26, 2014 the 4 pin square plug on the lower right. did it not come with a little harness plug in the box that fits in there? Honestly, I didn't get my package yet, trying to buy everything before install, si I don't know if it comes with it or no,... Speaker connector that you mentioned, is that the one wich connects amp to speaker or it should be different out?
Guest Posted January 26, 2014 Report Posted January 26, 2014 the 4 pin square plug on the lower right. did it not come with a little harness plug in the box that fits in there? Honestly, I didn't get my package yet, trying to buy everything before install, si I don't know if it comes with it or no,... Speaker connector that you mentioned, is that the one wich connects amp to speaker or it should be different out? the four pin plug is the high level input. its used if you dont have an aftermarket headunit since stock headunits dont have rca outputs for signal. take four speaker wires and attach one on each + and - on each of the two rear speakers or whatever speaker is closest to the amp. then connect those four wires you added, to the four wires that are attached to the plug that goes into the amp. matching polarity (+ and -) on the left and right channels for that 4 wire plug.
