2013 GTR SQ/IQC Competition Build
and here you see how the arms serve an additional purpose in allowing the subwoofer cables to flow across without being visible, they entire into the arm via a single grommet located right next to the terminals of the subs and is then routed to behind the back wall and down into the barrier strip platform:
next, mesh and plexi was attached to the led holder ,the led floodlight was fitted and wired up:
and finally, the painted front grille panel was assembled with a mesh backed by black grille cloth, with close ups showing the precision of fit and finish, this ist he piece that has magnets embedded in it to snap into the front wall opening:
now some misc pieces in the trunk. first is the mounting board for the mosconi 6to8DSP, it is a piece of mdf with spacers on the back and threaded inserts on the front. here it is before and after vinyl, along with test fitment in the car:
and here is fully wired up, with techflexed wires and labels, before being bolted into the car:
here is the little switch panel that houses the actuator controls and led switch, it is finished in the same type of precision as the rest of the trunk, the outter shell is back filled to fit perfectly onto a spot on the oem rear trunk sill panel, with the little snap in insert is painted blue to match the rest of the install:
here is the grommet drilled that allow the extension end from the power supply to be routed into the gas cap area, so the car can be plugged in for extended listening. normally there is a cap on the end the connector as well and the only time it will see electricity is when the extension is pulled out a bit and hanging on the outside of the car:
and here is the floor panel that houses all the barrier strips and wiretie hold down squares, under each of those red circles is a #6 threaded inserts, so everything is bolted in place:
and a quick shot of the plexi piece i made before it got painted on the border that protects the barrier strips from accidental shorting:
and here is are some shots of all the techflexed, heatshrinked and labeled wires as they are organized on the amp rack, while still leaving enough slack in them to account for the movement of the rack...was quite non-enjoyable doing this smile.gif
okay...so thats it and my fingers and hands are just about dead so i will keep the sumary brief.
overall this is the coolest project i have ever been involved in, i used to think that i am pretty anal about attention to detail, but seeing what joey accomplished is truth astonishing, and i have a hard time imagining doing the same repetitive thing over and over again to achieve the same level of perfection...
i really wish people can see the install up close to appreciate the fit and finish thats present, but for now, i guess these pictures will do.
omggggggg........I officially have a NEW FAVORITE RIDE ON SMD.... :) :) :) :) I wish one day sir....I could give u a demo.....and get a demo....pluse a ride around the block ;) ;) thx for the .stormtrooper love :) A+ craftsmanship also
Awesome man!!
If I make it to a Finals event on the West Coast, come out!!
If you or anyone's interested, here's a list of the mods:
2013 GTR (DBA Chassis R35)
COBB AccessPort ECU with custom map and tuning by Tim Bailey at Surgeline (Portland, OR)
Forgestar 20" deep concave rims custom offset and matte black color
Dunlop SportMaxx 600 Runflats
Project Kics lugs
Custom Brembo brake calipers (front and rear) -by ACG (San Diego, CA)
Endless NX72 brake pads (front and rear)
Password JDM carbon fiber engine manifold cover
Password JDM carbon fiber engine battery cover
Password JDM carbon fiber radiator trim panel
Password JDM carbon fiber rear exhaust finishers
Stillen front air dam skid plate
Greddy carbon fiber hood dampers
HKS SSQV4 blowoff valves
GotBoost 3" polished intakes and filter kit
Type1Racing polished intercooler pipe kit
Type1Racing downpipes, midpipe, and exhaust
Type1Racing custom slotted Titanium exhaust tips
Type1Racing s-coil adjustable suspension sleeves and springs
Forged polished res tank
Type1Racing filler caps
Type1Racing blue mirror kit and side view mirrors
CarKit bypass module and front/rear camera and power mirror module
WrapWorkz 3M 1080 Matte Gray and Brushed Black Metal vinyl wrap interior and exterior
Mosconi Zero Four
Mosconi Zero Three (x2)
Mosconi 6to8 DSP
Focal XXXL sound deadening products
XS Power AGM and Stinger power supply/wiring products
Pioneer P99RS source unit
MacBook Air (streaming of 24 bit/96 kHz and up) source unit
iPad Air (x2)
Gladen Aerospace 3 way front stage
Gladen 10" Zero Pro subs (x2)
Compustar Drone alarm
:runlaugh::lickscreen::omgwtf::drinks::dancing::woot::djparty::jump:
thats how this build makes me feel.
love how everything down to color/reflection of stereo knobs was though of. just amazing work. this rivals my other favorite ride on here, the BMW M3. but skylines have always been my favorite. just awesome work!
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
