Desousa93 Posted February 4, 2014 Report Share Posted February 4, 2014 (edited) is a 1999 Infiniti I30 PCM regulated? Edited February 4, 2014 by Desousa93 Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
Desousa93 Posted February 5, 2014 Author Report Share Posted February 5, 2014 Nobody? Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
MECHMAN Posted February 5, 2014 Report Share Posted February 5, 2014 is a 1999 Infiniti I30 PCM regulated? Your vehicle is not PCM regulated Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
Desousa93 Posted February 5, 2014 Author Report Share Posted February 5, 2014 is a 1999 Infiniti I30 PCM regulated?Your vehicle is not PCM regulated That is awesome. Is there an avbm for my vehicle? Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
MECHMAN Posted February 5, 2014 Report Share Posted February 5, 2014 unfortunately no it will not work with the stock alternator Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
Desousa93 Posted February 5, 2014 Author Report Share Posted February 5, 2014 If its not pcm regulated how wouldn't it work? Not trying to be rude n just wondering Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
MECHMAN Posted February 5, 2014 Report Share Posted February 5, 2014 The factory regulator is not compatible with the AVBM Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
Desousa93 Posted February 5, 2014 Author Report Share Posted February 5, 2014 Ahh I see. Thanks Can it be adjusted? Or do you know what it charges at? Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
MECHMAN Posted February 6, 2014 Report Share Posted February 6, 2014 Not with the factory regulator. The alternator would have to be converted to an external regulator.Then you would have the capability to adjust the voltage from 14v to 19V. Keep in mind the amperage will stay the same. The alternator in your vehicle is rated to 110 amps. What kind of power demands do you have? Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
Desousa93 Posted February 6, 2014 Author Report Share Posted February 6, 2014 (edited) Im looking to do 1500 watts for sub stage.. 250 for mids and 120 for tweets Was hoping big 3 a nice xs d3100 would do the trick if not ill go to a h.o alt Edited February 6, 2014 by Desousa93 Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
