Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
Sock is 52in^2 gonna be too much for my 8 since its sd is only a tad under 30? I did see some places suggesting you should double the SD but i wasn't sure what is good with all that but anyways thank you for drawling that up for me
This wIll work good.
welcome back guys , i have a built to do for a friend on his astro .. Im having a little bit of trouble designing his T-LINE with the subwoofer specs because it doesnt have a QMS reading and he wants it to be at 25HZ hitting hard, i believe the sub can take more and whats the best frequency to play with, space is no problem in it...bellow are the specs and whats going in , i appreciate some help..thx
12" - rockford fosgate ,hx2 punch rfd2212 dual 4ohm..
db drive A5.800.1D..800W rms @ 2ohm..
xs 14v battery..
300ho alt. by mechman..
big 3..
SUB SPECS...
FS - 29HZ
QTS - 0.48
VAS - 2.65
XMAS - .55
RMS 500W / 1000W MAX
MOUNTING DEPTH 5 13/16
SPEAKER DIS.CU FT 0.069
Ok getting ready to maybe try one of these boxes, I've read every page of this thread, or at least skimmed every page.
I have 2 Sundown SD2D2 12's:
Fs: 36.8 Hz
Re: 4.0 ohms
Qms: 6.06
Qes: 0.58
Qts: 0.53
Cms: 0.08 mm/N
Mms: 225 g
BL: 18.9 NA
Vas: 30.2 L
Sens: 86.0 dB 1w/1m
Le: 2.63 mH
RMS: 500 watts
If I did the math right I'm looking at around a 100 inch port with 170 square inch area, here's a rough sketch of the box, dimensions are 48wx18hx33d, please let me know what you think:
  • Who's Online   0 Members, 1 Anonymous, 1814 Guests (See full list)
