Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
Iam getting a lil better with this sketchup
I was bored a few min ago, and came up with this
this is a 12" phase horn, tuned to 37.5hz 13" cut out to install speaker in the horn, and to compress air when going in and out, for better velocity
This should slam pretty good, just gotta find a high, to mid/high Q woofer with a 38hz or so Fs, and this shoul slamm
Posted Image
Posted Image
Posted Image
phase horn...also known as a "Tapped Horn"
looky http://www.diyaudio.com/forums/showthread....;threadid=97674
can you help me out with a t-line for a elemental designs 6.5 eu-700 off a directed 600 at 2ohms for 300watts..
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
what kinda dimensions?
this is what the site has for them
http://www.edesignaudio.com/edv2/product_i...;products_id=33
Qts: .29
Qes: .30
Qms: 10.5
Fs: 28 Hz
Re: 3.2
Vas: 22 L
Mms: 50 g
Bl: 13.3 T*m
SPL: 85 dB
Sd: 114 cm^2
Xmax: 13 mm
Voice Coil: 38 mm
Magnet Width: 5.000"
Cutout Diameter: 6"
Mounting Depth: 3.500"
Weight: 7 lb
Total Height: 3.500"
Displacement: .04 ft^3
Outside Diameter: 7.25"
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
well, I have a design I did on sketchup, but the girls need the comp, i will post later
its a 28hz phaseline, TTB style unfortunatley
thats fine with me. and thanks for the help.. i was tryin to figure out the math for it and messed up on it.. it ended up bein 10 point somethin long for the port..
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
hmmm... this may be to complicated
its a phase line, a transmission line where the port and the sub share the same opening
ready?
Iam going to redo it, its to complicated with this design
sweet.. thanks.. i appreciate it..
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
  • Who's Online   0 Members, 0 Anonymous, 1465 Guests (See full list)
