Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
Looks correct but I have yet to build one.
I'm not sure but I think there may need to be more space behind the sub.
ForevrBumpn,
Can You invert subs on this design?
It would make it easier for me that way.
yeah whenb i designed it i had a plate on top first
Posted Image
  • 3 weeks later...
can some 1 design a T line for a 10" RE SX
SX SERIES
T/S Parameters
10"
Electrical Q Value -Qes: 0.29
Mechanical Q Value -Qms: 4.3
Total Speaker Q Value -Qts: 0.27
Free Air Resonance -Fs: 30.7 Hz
Equivalent Compliance -Vas: 21.8 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 85.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 1.9 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
SX SERIES
Product Dimension
10"
Mounting Depth - 6"
Mounting Hole Diameter - 9.25"
Overall Diameter - 11"
Bolt Hole Circle - 10.125"
Motor Width - 6.5"
Motor Depth - 3.25"
Basket Depth - 2.75"
Displacement - 0.15 cu. ft.
Weight - 23 lbs.
TRUNK SPACE
15" height x 32" width x 25" depth
this is what i came up with.. for an eu-700 or 7kv.2 6.5 sub
what you guys think
Posted Image
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
what you guys think
Posted Image
i went through the math and i am completly wrong.. sucky.. lol.. i did the math for two subs.. can anyone else confirm this..
thanks..
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
ok, I am wanting to try out a t-line for my MA audio HK15X2. The T/S parameters are:
Fs - 29.581
QMS - 3.965
QES - .517
QTS - .457
Vas - 147.723 (this is all they gave me)
Would this work out well in a t-line box? I have come up with 150^2" of port 9.75ft long.
If a t-line wouldn't work out well, what type of box would you suggest? I want to try something other than the regular sealed and ported boxes.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
SX SERIES
T/S Parameters
10"
SX SERIES
Product Dimension
10"
Mounting Depth - 6"
Motor Width - 6.5"
Motor Depth - 3.25"
Weight - 23 lbs.
TRUNK SPACE
No Help??????
  • Who's Online   0 Members, 0 Anonymous, 1465 Guests (See full list)
