09 Chevy Impala Lt Build,Crescendo audio,Phoenix gold,SHCA
So I have some good news and some bad news lets start with the bad news I am still waiting on my amp to be repaired by crescendo. So I just ordered another 1100.4 two of the channels was not working.
.I also have a bad wiring some were or the speaker is bad or getting grounded out. when I was doing the big3 one of the wire hit the pulley and there is a small hole causing the belt to go bad. The good I have a singer alternator on the way .
Good news time found the problem was not with the 1100.4 it was due to one of the jack in the head unit being bad.
I also found the problem in the front right speaker it was getting grounded out on the door frame causing the amp to make buzzing noise.
I also got a new pulley just waiting on the singer 275 amp alternator to get here so they can be installed at the same time.
Pics are on the way
Where did you get the spring lifters? Also how do you like that nvx sound deadener?
You can get the spring lifters from your local auto zone.The nvx sound deadener it is alright cant complain.
So I got the car metered on my first run I did a 138 on my second run I did a 141.2 db second place singer alternator might be installed this week
  • 3 weeks later...
How do you like the alternator?
I havent really had a chance to try the alternator out because the car has been parked for the last two weeks.
But with the ac on and the system playing i drope to 13.8 volts maybe by this weekend i will try it out after i get every thing tweeked and dialed in.
