ssa zcon box help
youngbass98
i just got a ssa zcon 18 and i need help designing a box my are demensions are 35-25-30, (i could go bigger or smaller on all of those demensions if needed)
7 cubic ft after displasment
1.5mdf all the way around
slot port tuned to 32 hz
i listen to decaf
ran of ss rubicon 2500
if someone could design me a box that would be greatly appreciated, thanks
Edit: sub up, port back
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
well i didn't get any responses so i designed my own. can anyone give me any feed back on it, is it good or what do i need to change
06 monte carlo
2 12 rockford p3s
ct sounds 125.4
Looks good to me good job.
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
Well I did notice that you only put the thickness at .75 but you mentioned you wanted to do 1.5 thickness. Also you said you want 7 net.. you have 6.5..
But what you have in torres in fine. Or you could change it to match what you wanted originally
Setup:
Xs D3400/ Xs XP3000
And if your max dim are 25-35-30... or w.e how do you have one of your dim as 38...
I skipped that usually people are good at that. And just briefly check net and port area and tuning to be all decent values..
Setup:
Xs D3400/ Xs XP3000
And if you box it 26 deep you cant have a 30 inch long port. Unless you planned on bending it..
Just take your time and measure 3x cut once
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 1298 Guests (See full list)
