2 port wall extension question
shadowcaster
Hello guys so i got my design done now im having issues with port extension length.here is the torres
which when i do a quick sketchup i see this
where im lost now is the extension length.torres says port length is 22in physical port is 17.75in. i have 16.5in from the front of the baffle to the rear of the box leaving 1.75in from the rear wall(half the 3.5in port width)which leaves 1.25in remaining..when using the physical port number.or do i need to use the port length i entered 22in-16.5in= 5.5in
thanks guys and on a side note while putn this together the mailman came
2000 blazer LS
240 mechman
2 b2 HN v3 15s
crescendo bc5500 @.5
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/
142.8db MECA
2016 PA state champ mod 1 class
I just went through this. I had to do some searching but you only use the port length not physically length.
So like you did measure front to back down the center line and subtract half the port. Then measure from the centerline to the right and left the remainder of the port length. Also you don't divide it both sides will be 22 " long measured from each centerline of the port.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Thanks alot sir.
if i understand your answer correctly i have to subtract 16.5in(front to back)from 22in(port length)leaving 5.5in(length of extension)to the left and right sides?
im thankful for the help.math was never a strong subject
2000 blazer LS
240 mechman
2 b2 HN v3 15s
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
142.8db MECA
I have noticed from your screen shots that you are doing a double baffle,so you need to add that to Torres under "# of extra baffles" as that will change your net volume and tuning.
yes i am 2- 3/4in MDF making some changes
2000 blazer LS
240 mechman
2 b2 HN v3 15s
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
142.8db MECA
Yes that is correct. Your ext. Left and right will be 3" long each. Add that to .75 + half your port which is 1.75 . Add them together and you have 5.5" then + 16.5 = 22 " port length. Hopefully that makes sense.
80prs
DC 180 alt
makes complete sense now thank you guys for all the help
and to kicker8940-yes it did change a bit but not by to much
2000 blazer LS
240 mechman
2 b2 HN v3 15s
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
142.8db MECA
  • Who's Online   0 Members, 0 Anonymous, 1242 Guests (See full list)
