Installed component speakers, new buzz problem now
The previous owner of my car had 4 pioneer speakers and factory tweeters hooked up to a 400 watt amp. I took out two pioneer speakers and attempted to take out the factory tweeters in favor of a pair of Alpine SPS-610c's.
Factory tweeter wiring was a no-go, straight back to the head unit, could not get the SPS-610c wiring through the door boot. So I hooked up my Alpines and drilled a hole for new tweeters.
I now have 4 tweeters and 4 woofers, but I introduced a buzzing sound in the front speakers. It's a low hum when the car is on, and oscillates up and down as I drive. I did not have this problem before, so I'm not sure how the alternator could possibly suddenly become a problem.
Any ideas on what I might have done wrong? Thank you for any input.
how do you have your wires ran?
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
The factory tweeters run straight back into the head unit, so I connected my woofers with the connectors that were previously connected to the Pioneers and just drilled new holes for the Alpine tweeters. The Alpines I have, they have 4 connectors on the woofer. The extra two are for a crossover connection, which then connects to the tweeter.
check the speaker wires to see if they got cut on metal could be grounding out.
also double check you ground wires to make sure they are not loose could be something stupid like that
ya thats all you can do just go back thru whatever you did and just double check everything
Great advice man. One of the screws was drilled into a wire. Patched it up, pulled some length, screwed it back in. Sounds great!
  • Who's Online   0 Members, 0 Anonymous, 2106 Guests (See full list)
