So i'm looking for a 600w actual RMS monoblock, that is 1ohm stable, OR a 2channel 2ohm 300w RMS per cannel, OR a 4 channel 2ohm 150 rms per channel.. I'm looking for a decent brand that doesn't bulls**t their ratings and it has to b less than $200 which is the catch..
I would like the crescendo symphony 600.1 but not sure if they are 1ohm stable, also saw the Pioneer GM-D8601, but not sure if I trust their ratings..
Any suggestions?
The pioneer puts out the power, clean and 1ohm stable, stays cool. Great bang for the dollar. Edit; the 8604 is 150rms at 2ohm and is also 1ohm stable.
truthsayer
Thanks heaps for the replys guys,
I should have mentioned I'm planning on running midwoofers, 2ways and tweeters off them so I need full range of frequency as well, the pioneer lists the frequency response as 10-240 hz, is this likely? I doubt it runs at 10hz? Would it cut out at 240hz?
The audioque, looks like it may work, I'm a bit too scatterbrained to do calculations right now.. I've not heard of audioque before, does anyone else have an opinion on them (no offence, just fishing for info)
I also figure out if I run 8ohm midwoofers instead of 4 ohm, I won't need to run a 1ohm stable amp, 2ohm stable should run fine.
--didn't see the SoundQubed, thanks heaps guys its food for thought
One last noob question, if I had a 2channel amp can I run different loads off each channel? i.e 2ohm off one and 4ohm off the other?
  • Who's Online   0 Members, 0 Anonymous, 3176 Guests (See full list)
