PLANET AUDIO BB2400.1
BassMonkey
The only planet audio amp that is omay is the bb2400.1.
its a budget amp, it will do close to rated but you need good
voltage and a good electrical system there power hogs.
if you dont have the electrical domt run it
No one here will recommend it, including myself. You'll more than likely receive a decent amount of flac for starting another thread about this amp too; there are dozens of threads about this amp on this forum asking the same question. Just heads up.
As for my opinion
do not by any means buy it. You wont get anywhere near rated power.
Also, these amps have absolutely ZERO resale value. So unless you plan on using it for years to come (which I highly doubt will happen since it's most likely going to fail on you) don't buy it. Save money and buy a decent korean board that has some resale value so int he case you want to upgrade or something you have equipment you can make something back on.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
Well i am thinking of buying 1 or 2 batterys to run along with it 0 gauge wire All the way around.Might buy alt depending on what car i decide to put everything in
I've got one of these sitting in my closet. Never ran it though.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Well if its junk what about this http://www.sonicelectronix.com/item_43838_Precision-Power-PPI-BK1800.1D.html .I seen pictures of the guts and they don't look bad
The boards on those amps are solid for the price.
oh lawd.
  • Who's Online   0 Members, 0 Anonymous, 582 Guests (See full list)
