What options do i have wiring my subs?
Skax
ok so i wanted to know all of my available options for wiring 2 dc level 4 12's dual 2 ohm
i have them like this right now but the way my box was built it has a hole in the back big enough for 2 runs of speaker wire so i was going to wire each sub to a seperate channel of my 2500bdcp and i would highly appreciate it you could tell my my available options for wiring each sub and a diagram
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
RF 2500bdcp only has one channel, so you can only get .5, 2, or 8 ohm loads out of two, dual 2 ohm voice coils.
Most mono amplifiers have two positive and two negative speaker outputs, but they are internally on the same channel.
EDIT: Don't do .5ohm...
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
ahh thats the answer i was looking for so if i wire each sub like such 1_2ohmDVC_4ohm.png
then the final impedence will be 2 ohms correct?
another question: since i dont have the electrical for 2ohms atm and was considering 8ohms what kind of wattage you think i would get on a wild guess?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Right, the final impedance should be 2 ohms. That's series, parallel.
You could try 8 ohms, but I have no idea what the power will be, its hard to tell without a way of measuring it. Maybe half of what it can do at 4 ohms.
It would be fine to run at 2 ohms, just watch your voltage. If it's dropping too much, set the amplifier gain lower.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
yeah my problem is im on stock alt and stock battery ganna upgrade to d975 as soon as i get my amp fixed and wires in then save up for the d975 and a d3100 then alternator lastly just the fact because idk how much more this car can take lol i can always take the batteries out and throw em in another car
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
If you're worried, just wait it out, save up, and then build a good system. That's the safest way of doing it.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
yeah im ganna do like you said ganna just throw in a voltmeter watch my voltage at 2 ohms and just keep the gain down until i feel like my voltage is comfortable thanks for the help tron
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   0 Members, 0 Anonymous, 2853 Guests (See full list)
