Questions on my electrical
1. I would do both if you have the wire to spare
2 grounds in the back to frame and 2 grounds to the front batt and 2 grounds off of the front back to the frame. also do big 4
2. I would go with which ever one has better idle 320 one should be fine would think it has better idle.
3. i would do 2 250 ones for each run.
Most important Buy more batts and get that HO alt i would go with minimum 2 d3100s but if you have the money go 3-4 d3100s adn buy a voltmeter if you havent yet to keep and eye on voltage or you could blow and amp.
The plan is for 250A on both ends of each + run from front to rear bat/bat's so 2 250A's per run
Looking at the mechman site the 320 is quite low on the idle amperage.
Elite series 370A
S series
I'm budgeting myself around $4,000 for Batteries, Alt, Subs, Amp and box plus installation parts. Doing all install myself.
Minnesota! Y U NO GET WARM!
no real reason to ground to your front battery! it will take the shortest path. the ground from bat to bat would just be a waste! do 3 runs of rear battery to ground then! not needed but can't hurt. keep them under 3ft if possible. i would also put 2 fuses between each battery. that's what i do. one 1ft from each.
as far as .5ohm that i can't answer. i know that if your 2???w system draws lets say for just reference 200 amps at 1ohm then at .5ohm it will draw almost double so 400amps (this isn't exact just a example!) so 5000w at .5ohm i think (think) a 320amp alt on 3good batteries Would be ok. i would run more then 2 at .5
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
Yeah now I wish I bought less of the black wire lol. Guess I can run it as positive if I run outta the green stuff!
I'll take some! ; )
but yea a extra run of power can't hurt. or just triple up on bat grounds. I've always had 2 grounds to each battery. never ran 5000w (yet waiting on new car!) but at least you have it! wish i had all that wire!
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
I'll take some! ; )
Yeah its nice stuff. I can't believe how out of control I'm getting with this build. I was just planning on a couple 12's for some bump and it has manifested into a whole new level. I have never had a nice system so I wanted to do it right! I have added up what I have spent so far and I just shake my head lol. Never in my life thought I would spend over $500 dollars on wire lol. $1000 on batteries? wut dafuq lol. Well its sure is fun though.. just can't wait for it to warm up so I can get started on this.
post #69 woop woop!
haha, like most here in the last 13yrs of my audio addiction I've spent tens of thousands of dollars. this build i have barely started yet Is already $4,000 in And I'm not even half done yet!
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
  • Who's Online   0 Members, 0 Anonymous, 1316 Guests (See full list)
