First amp repair
FknCrawler
Mosfets in my MB Quart DCS480 blew awhile back ago and I ordered the parts to fix it. I was so scared to do it having no experience or knowledge on how to even solder. Said screw it and did it, was much easier than expected.
I have a problem though, after only about 10-15 mins of full tilt it's very warm to touch. Only using 2 of the channels. 2 Skar RPX65 on each channel(don't have enough/the right RCAs yet). I tuned this amp with a DD-1 before it blew up.
I'm scared it's going to blow up again... Although I have enough parts to repair it 10 times.. I'd rather not.. Don't want to risk causing even more damage to it.
1992 Honda Civic CX Hatchback
K24a2 Swap
I believe when the mosfets go there is another part inline that I think usually needs to be replaced at the same time. I think it may be some type of resistor? but idk for sure. that may be your problem
Brandon
2000 Furd Ranger supercab 4x4
System:
welding wire throughout the truck
USalts 390amp Hairpin
Juicebox in stock location
8 Banks of maxwell supercaps
2 American Bass Vfl 1100.1 wired to .35 each
2 Fi Audio Sp4 18's ( the DD sc 9918's smoked)
Pioneer radio with Soundstream PA mids Powered by a nice sized soundstream 2 channel
It's pronounced (dain-ja rain-ja) :ph34r:
2001 2 door focus
1 DD9918 SC
He said in his first post that the mosfets blew.
Brandon
System:
2001 2 door focus
1 DD9918 SC
the ones in the out section or the power supply the power supply will use one kind the output will use a pair also what did u replace with it and what gate resistor?
It was the smaller ones on one side, I don't know what gate resistor and I replaced them with the same parts. I think they were the power supply mosfets.
Only 2 were burnt up but replaced all of them in that group.
K24a2 Swap
Sometime tomorrow I'll take it back apart and look over the board and check some resistors.
What should I do if I can't find a problem... I really need to fix this overheating problem..
K24a2 Swap
I would consult someone with amp repair experience. Either PM someone on here or call/email an amp repair business.
Sorry and good luck bud
Brandon
System:
2001 2 door focus
1 DD9918 SC
Just gonna get a nendo s800.4, in the mean time I'll keep an eye on the amp incase it wants to go up in flames.
K24a2 Swap
  • Who's Online   0 Members, 0 Anonymous, 661 Guests (See full list)
