It's Me Posted April 6, 2014 Report Posted April 6, 2014 I Got Some Question About The Eclipse DA7122(1 Channel Class D Subwoofer Amp) 500RMS@[email protected] 1000RMS@[email protected] My Batt Volts Is Low 14's At The Amps Pow/Gro. Does it do rated power? Or more or less? Needing To Know,So I Can Set My Gain. Its has. Low Pass Filter 50-200Hz Subsonic Filter 1-60Hz High Pass Filter 50-200Hz I thought 1 Channel Class D Amps Didnt Have High Pass Filters. Im Using A Single SoundQubed SDC 15'' D4 600RMS, In a 4cf.Net Tuned To 35Hz, I Listen To Rap, So What Should I Set My Filters To? What Are The ICEpower Amplification Modules?What Do They Do For The Amp?
Deeznutz Posted April 7, 2014 Report Posted April 7, 2014 Eclipse has always been high end. SQ amps from what I remember. They would not be around if they were bad. lol. They still hold their value on Ebay. They can probably due rated power. 600W is under the rating, so you should be fine. Apparently they do make "FULL RANGE" Class D amplifiers. Do a google search "Full range class D amplifier" I see Infinity has full range class D amps! That tells you that Eclipse was using this technology early on! -Frank
It's Me Posted April 8, 2014 Author Report Posted April 8, 2014 whats up with the ICEpower,what should i set my LP/SF/HPF to?
