WTB Zv3 12 d1
Chucklezz
Are you only wanting to run a single? If so, why the D1 coil? If you want to run a 1 ohm load final at the amp, the D2 is what you want. If you are wanting to run .5 ohms final at the amp, then the D1 is the one you want. If you plan on running the 3500 Watt amp at half ohm, that's way too much power.
If you are looking to run two of the D1 coil subs, then that will wire up to a final load of 1 ohm.
  • Who's Online   0 Members, 0 Anonymous, 2859 Guests (See full list)
