BOX FOR 2 ORION 12" H2.2
ngo
More info needed.
What amp will you be using and what fq do you want it tuned to?
Also what are the overall dimensions that you have available to work with?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
What is your goal for this system also.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
I'm going to use 2 skar 2500.th fq 38hz.I think that I'm going to use a ford ZX3 to put all. It's my challenge....
Easy putting it in there. The hard part will be getting your electrical up to handle 5krms.
141 on music.
Ok you want numbers is that all? If it is build a Burp box with aero ports so you can change the tuning at will and test over and over and over and over.
141 on music.
To do that I need the specs of that box and the the aero port...because I don't have a program to do the box.....I work alone...
Torres box calculator. But when t comes to burp boxes you really can't go by mani factor specs of a box it should be in. A burp box will play 1 note and 1 note only.
141 on music.
  • Who's Online   1 Member, 0 Anonymous, 5316 Guests (See full list)
