we are now in february of 2014 and my new project is to replace all the gaskets on the engine and replace the timing belt and water pump
battery disconnected
some more stuff out
this was the back of my throttle body
i got this cleaned up
got a new water pump put on
another pic of the cylinders
well i didnt take any more pics after all this cuz i was getting pissed off at everything but all the seals got replaced and the engine runs like new now!
Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car
to add some power and style to my car i decided to buy and AEM short ram intake
took out the old intake system
the old intake system with a K&N filter i bought like 3 years ago
my new intake
the new intake in my car!
found this little piece for the front bumper in the junkyard which will help with airflow management
i sanded is down to get the old paint off and then gave it a fresh coat of black paint
this is how the front looked like before i found this piece
this should help with air flow now
well time to start building my instrument pod interface to have everything situated right where i need it to be
im gonna run the LED switch, Volt Meter, and bass knob wires up the driver side A-pillar
getting the wires run
finished running the wires up the pillar
got the wires run thru the headliner to where the dome light was originally
forgot to mention i also got the microphone pic up thingy wired up to this spot to be attached to the pod
got the initial frame setup for the pod
wrapped and ready for glass
glassed and ready for sanding
the inside of the pod
got the brackets glassed on
now to get the face prepped for the switches and meters
got the pod mounted on
