Since this box is built and gone I just thought I would throw up build pics it was a difficult box with all the angles and the space restrictions and specifics he said he wanted. Was a fun build just a couple DC lvl4 on a 3.5k.
This was the beginning plan
Once I figured out the angles and airspace made some cuts
Starting putting it together
Taking some shape now
So slanted
First Baffle
Second Baffle
Getting ready for the holes Right after this I realized the plan from the beginning was not going to work like I thought, stared at the wood for hours.....
Finally figured it out
Decided that I would make some rings and make the ports come out a bit more the angle and depth were not working for me
Moch up
Time to start adding color
color moch up
Getting it all glued and screwed together
Taped it off and added second color for a nice pop
ports are better with badass duct tape right?
After 5 coats of paint
All finished up
This gonna hit hard wth teh 15's
Check Out My 1986 Chevy Caprice Brougham Classic Restoration:
http://www.stevemeadedesigns.com/board/topic/184647-1986-chevy-caprice-restoration/
Well he has some constraints that if I had known about going in to this build I would have designed differently. The ports are getting choked a bit due to the seats. We got 147.3 out of it though. He did not want me to fiberglass the inside wanted to do it himself I think that will help some. He is getting alot of voltage drop as well so fixing those should get him close to 50's
Nice box
Thanks Bro!
Different but I like
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
  • 2 months later...
happend to miss this, huge shout out to this sexy mother fucker, box sounds awesome! nothing but quality in that box, im running a stock alt right now so drop is a bit much, but ports are getting choked out a bit so the lows suffer, but thats my fault for not taking that into account, mind you he never looked at the truck, but on the higher end this thing KILLS, im happy with it, but theres always a rebuild right? :twirl: hell be designing my next idea in a few months, thanks again babe<3 oh and TDHFTMFCSW amirite?
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Top notch stuff. I wouldn't expect much less though! Good work yet again brother. :P
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
  • Who's Online   0 Members, 0 Anonymous, 856 Guests (See full list)
