Dummy here...need help.
Where exactly is the engine block can someone circle good grounding spots for my engine block? would you guys recommend grounding engine block to chassis or battery?2012_nissan_versa_14.jpg2012-Nissan-Versa-Sedan-1.6-S-4dr-Sedan-
i was thinking about either using this as an engine block ground
this one is about 3 feet away from the battery.
or this
this one is about 1 foot away from battery
Hey man just trace the original engine ground to the battery and add the extra wire atop of that ground. Simple, no need to get technical
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
