jdshott Posted May 1, 2014 Report Posted May 1, 2014 This is only a rough guide i CANNOT tell you how to make it sound good to you . play with each setting to get a feel for the different frequencies. OK so your front (tweeters ONLY) set between 8KHz and 12KHz rear set between (MidBass ONLY) 500Hz to 6KHz Sub (29Hz to 80Hz) this is a very ROUGH guide. Frequencies can sound very different due to, each persons personal prefrence , car , and equipment. try to match frequencies to speakers output range EXAMPLE do not set your tweeters to accept 1.25 KHz if they are rated @4KHz to 22KHz yes i skipped some frequencies i know ! i did this just for example . No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
evo90 Posted May 1, 2014 Author Report Posted May 1, 2014 This is only a rough guide i CANNOT tell you how to make it sound good to you . play with each setting to get a feel for the different frequencies. OK so your front (tweeters ONLY) set between 8KHz and 12KHz rear set between (MidBass ONLY) 500Hz to 6KHz Sub (29Hz to 80Hz) this is a very ROUGH guide. Frequencies can sound very different due to, each persons personal prefrence , car , and equipment. try to match frequencies to speakers output range EXAMPLE do not set your tweeters to accept 1.25 KHz if they are rated @4KHz to 22KHz yes i skipped some frequencies i know ! i did this just for example . Yea its rought, but its better than nothing! And i always confus then i see dis Khz or hz, or what ever, but thanks. Which i need tune first head unit or amp? My Build Logo http://www.stevemeadedesigns.com/board/topic/157575-volkswagen-passat-b5-2001/
jdshott Posted May 1, 2014 Report Posted May 1, 2014 Tune the head unit first then set amps (you may need to adjust both @ the same time to match output sounds) . REMEMBER to set your gain on you amp or amps all the way DOWN . adjust amps only after you are happy with the sound . No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
jdshott Posted May 1, 2014 Report Posted May 1, 2014 http://searchnetworking.techtarget.com/definition/kHz http://en.wikipedia.org/wiki/Hertz These 2 links might help you understand the Hz and KHz this one is just a simple explanation http://www.ehow.com/facts_7260646_definition-crossover-frequency.html No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
evo90 Posted May 5, 2014 Author Report Posted May 5, 2014 http://searchnetworking.techtarget.com/definition/kHz http://en.wikipedia.org/wiki/Hertz These 2 links might help you understand the Hz and KHz this one is just a simple explanation http://www.ehow.com/facts_7260646_definition-crossover-frequency.html Thanks for a links! My Build Logo http://www.stevemeadedesigns.com/board/topic/157575-volkswagen-passat-b5-2001/
evo90 Posted May 5, 2014 Author Report Posted May 5, 2014 I just wondering, how properly set Gain, free distortion and no cliping for 4 channel amp. I know one way how to set gain properly using smd- cc1 but what kind of frequensy (hz) i need to choice for 4 channel amp? My Build Logo http://www.stevemeadedesigns.com/board/topic/157575-volkswagen-passat-b5-2001/
jdshott Posted May 5, 2014 Report Posted May 5, 2014 http://www.the12volt.com/installbay/forum_posts.asp?TID=85479 No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
evo90 Posted May 5, 2014 Author Report Posted May 5, 2014 http://www.the12volt.com/installbay/forum_posts.asp?TID=85479 Thanks again. My Build Logo http://www.stevemeadedesigns.com/board/topic/157575-volkswagen-passat-b5-2001/
