matt.b Posted April 25, 2014 Report Posted April 25, 2014 is your power and ground arching and where is your main ground for that amp
Ahmed Johnson Posted April 25, 2014 Report Posted April 25, 2014 Just saw these pics. Please, oh lord please, take pics of this when it eventually catches fire. You aren't at all concerned of all that extra wires and crossed wires and mix and all that other shit you got going on? Also, why do you have that amp set at full range?
FocusOn20s Posted April 25, 2014 Report Posted April 25, 2014 Just saw these pics. Please, oh lord please, take pics of this when it eventually catches fire. You aren't at all considered of all that extra wires and crossed wires and mix and all that other shit you got going on? Also, why do you have that amp set at full range? ah man you're just hatting on his wonderful setup
Blake Farrar Posted April 25, 2014 Author Report Posted April 25, 2014 Lets make this easy and simple. you have been told to check wiring voltage finale impedance gain boost and so many other suggestions I'm running a t400-4 which they like to get hot. Mine is in my trunk with stuff in it just about all the time. Running full tilt correct set gains no boost with no heating issues. Voltage is fantastic since its my only amp stalled same t400-4 with a t1500.1bdcp stock electrical (105 amp alt) big box with limited space for the amps. Still no issues and the 1500.1 gets hot so both of them side by side with no issue. you are the issue with the install. Something your doing the amp don't like. well problems do happen when you have to learn everthing by yourself, the problem is realy even happening now witch makes it even harder to find the problem and ive checked everysingle thing in my car and from all everthing i know it looks good but im not a pro so there could be something wrong or my amp could be messed up it happens and it might not be my fault if only i had some people around me to help.
Ahmed Johnson Posted April 25, 2014 Report Posted April 25, 2014 Making sure bass is shooting out both sides in case you're in the middle lane is a sure fire way to add DB's and shut the streets down
Blake Farrar Posted April 25, 2014 Author Report Posted April 25, 2014 is your power and ground arching and where is your main ground for that amp
Ahmed Johnson Posted April 25, 2014 Report Posted April 25, 2014 Just saw these pics. Please, oh lord please, take pics of this when it eventually catches fire. You aren't at all considered of all that extra wires and crossed wires and mix and all that other shit you got going on? Also, why do you have that amp set at full range? ah man you're just hatting on his wonderful setup lol, you right. I cant stand hatters so why would I become one
Blake Farrar Posted April 25, 2014 Author Report Posted April 25, 2014 Just saw these pics. Please, oh lord please, take pics of this when it eventually catches fire. You aren't at all considered of all that extra wires and crossed wires and mix and all that other shit you got going on? Also, why do you have that amp set at full range? okay first off its messy cause ive been messing with it and im about to run new speaker wire than im going to wire tire it all together and its not on full range i didnt mean to post that pic its an old one.
