Alright iv already got 1 and im thinking of picking up 2 more but have sum questions first.
SUBs- 3 15" Competition Subwoofers
600W Rms
1200W Max
Dual 4-Ohm Voice Coils
260 Oz. Double Stacked Magnets
Mounting Depth: 7.8"
Mounting Diameter: 14.1"
Optimum Vented Box: 3.5 Cu/Ft
Round Port Diameter: 6" x 9"
Square Port Area: 3" x 9" x 11"
Optimum Sealed Box: 2.0 Cu/Ft
Tuning @ 40Hz
will be going into a 1990 4door honda accord ex trunk.
#1. it requires 10.5 can i fit that in my trunk? im not sure what the dimensions of my trunk are yet.
#2. Wat should it be tuned too? I wanna be able to play music but maybe a lil later do competitions.
#3. wat amp an wire should I use and wat other upgrades?
#4. Sealed or ported?
#5. Can somone design me the best box for these that i will be able to compete with an stuff
~REFS~
-CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D)
-SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
/morning bump
~REFS~
#1. Need pics or dimensions to decide that, you can always open into you cabin for more space.
#2. Removeable port would be best, if you dont want to do that then go around 35hz
#3. Amp should be around 2000 @ 2ohm, 0 gauge and lots of power would be best
#4. Ported
#5. Amatt's got skillz, ask him, he has his own thread for people.
up up and away!!!
~REFS~
1. I don't see a noob getting 10ft out of a Honda trunk. If you're good then anything is possible, but seriously if you 're having to ask us these questions then I don't think you're that good.
2. I'd go for 35hz for daily music and part-time competing. It would be best to do some kind of removable/swappable ports though.
3. Run all 4 coils parallel for a final 0.67ohm load and power them w/ a single Sundown saz-1500d. You'll get 1800-2kwatts w/ that setup. I always run 8awg speaker wire. Its overkill for some setups but keeps you from having to upgrade later on.
4. Ported, nuff said.
