94 Ford Beast-350 OBS CCLB - Motor is done, need to sell, questions-please help
Next I started on the wire harness. There's a bolt that holds the main connector together.
10379560_587149878060813_692536883960701
10575158_587149891394145_328342160701120
10560275_587149918060809_861730393904837
Pulled the distributor cap.
10553815_587149941394140_368852765683147
10484559_587149958060805_790133024781867
Then the cap base. Also the air something or other clip there in the middle, I can't ever remember what that thing is called. It needs to be replaced though.
10497205_587149971394137_120217920648685
This hose needs to come off and here's a closer look at that air thing. Also the throttle positioning sensor (part with the red oval thing on the right) gets unplugged.
10536816_587150004727467_655250594861968
10481654_587150014727466_340403499192018
Then unplug this sensor, can't remember what it's called but it's right behind the distributor on the intake manifold.
10553957_587150021394132_420358137627558
Remove these vacuum hoses on the tree back there. Also the single wire there right behind the distributor.
10446096_587150048060796_288732429358852
Hose off the fuel regulator.
10010144_587150061394128_353315936041370
10531452_587150078060793_640745417966647
Removing the throttle cables from the throttle body.
10582906_587150298060771_107004526728746
10604615_587150311394103_143490887970634
10582831_587150338060767_110876540442383
Not sure what exactly this is but it leads to the emissions/smog stuff. That tube comes off.
10548907_587150348060766_826112829152684
You can see around the black gasket, there are 4 bolts for the throttle body. Throttle body removed.
10515192_587150381394096_628654550582203
Now let's remove the main harness. Starting with the fuel injectors.
10428407_587150398060761_233559582381695
10623739_587150414727426_817446125176236
There are a few nuts around the intake manifold holding the harness bracket on.
10533834_587150471394087_313463188559693
4 nuts from that bracketing.
10562724_587150481394086_670442669009318
Deep in the depths, another wire to remove.
10382362_587150504727417_387359252300215
10549036_587150524727415_193898938987916
Then on the A/C, remove this harness plug.
10560349_587150531394081_444762846436100
10580796_587150548060746_756072845578148
And boom, harness removed.
10428295_587150571394077_863563359467772
This is the neck that holds the thermostat in. Looks pretty bad. That's gonna get replaced.
10548259_587150591394075_562335441718035
10551700_587150614727406_198608280479523
Next remove these hoses.
10465533_587150641394070_179421248145554
10608730_587150651394069_258429556631878
Next I worked on the fan shroud and the hard line running along the top. There are two bolts on the top, under the black tabs of the hard line.
10553856_587150661394068_523356527550782
10560424_587150688060732_677003539145971
Time to remove the fan. There's 4 bolts there.
10504877_587150708060730_913443866583126
1500854_587150724727395_6610589982818462
There's a bolt hiding under there. This is from under the truck, where the alt bracket was but you can't see this behind the smog pump.
10622787_587150938060707_173579728805001
I ended up cutting these two hoses off, they'll get replaced.
10372828_587150958060705_728937403965740
Smog pump gone.
10493073_587150964727371_240412203205693
Pull the fan pulley off, it's loose from when the fan bolts were removed.
10465471_587150994727368_285723530095276
10333455_587151008060700_899732078533448
Remove the tensioner and I may replace this also.
1973946_587151018060699_2647292080980671
Start removing the AC pump. Make sure you have your system discharged before you start working on all this. Otherwise you're screwed. Well not really but you know what I mean. 4 bolts to remove this.
10256624_587151041394030_673231989632590
10557568_587151054727362_190224361272817
10604603_587151061394028_471763463696273
Next up is the power steering pump. This is getting replaced as well. I have one, have had it for awhile. This was some aftermarket one, and it's fine, works great but it's loud and whiny as hell sometimes. So that's going, and this is as good a time as any.
10272526_587151084727359_608276761438665
Pull these hoses. If you can remove all the fluid you can before doing this, or it's gonna be a huge mess.
1889049_587151104727357_6155112417863064
out
10549189_587151114727356_728266226427005
10495009_587151131394021_791484789533378
Lower radiator hose. This was replaced when I removed and did the oil cooler delete mod.
10557544_587151151394019_156052894659568
You can see the big mess under there.
10560477_587151174727350_247184027920071
Should've taken pics of the water pump removal, but I got wrapped up in the bolts and stuff. All the bolts need replacing.
10582928_587151208060680_667745015284053
This is what it looks like under it. Not good. See all that rust. Yuck!
10495692_587151194727348_541840199992543
10553838_587151228060678_331342764027727
Looks pretty dirty to me.
10624079_587151244727343_821222063274791
10626260_587151254727342_462280875771829
Time to pull the crank pulley
10382355_587151291394005_127363286442360
10620134_587151314727336_418506333723350
10604603_587151324727335_558655762218653
At this point I decided to pull the front of the truck. I wanted to replace the radiator, ac cooler, transmission cooler, and add a new oil cooler as well. So Why not.
Remove these screws on top of the headlight frames.
10499631_587151344727333_362237380449910
These on the grill
10481644_587151358060665_681685707951878
10575413_587151378060663_407811240271259
This screw under the ford logo in the center of the grill.
1836720_587151391393995_5562185270293046
10553946_587151404727327_383120311775694
10549173_587151421393992_326072945619439
