KICKERKX1200 Posted March 19, 2008 Report Posted March 19, 2008 i am doin a blow through in a 03 ranger ex-cab for a friend. it will be 2 2008 12" l5's. wanting it tuned around 34hz. can any one suggest total cubic feet and sq inches of port that would give a wow factor for being two 12's. or should i just use the specs that kicker has which is i think 3.25cf plus port. also he will be using a zx1000. thanks for any help.
KICKERKX1200 Posted March 19, 2008 Author Report Posted March 19, 2008 well change of plans. everything is the same but he is going to get 2007 L7 12's instead of the L5's
Team Sundown's Charles Posted March 19, 2008 Report Posted March 19, 2008 well change of plans. everything is the same but he is going to get 2007 L7 12's instead of the L5's 4.00 cft net 38.00 square " of port area 16.00 inches of effective port length 9.50 square " of port area/cube 2.00 cubes/sub 34.23 hz 1993 Mazda Mx-3 Subs: 2 18" DC Audio Lvl 4 D.7 Highs amp: Sundown SAX-100.4 Sub amp: Sundown SAZ-3000D Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's Dampening: 120sqft 80Mil Thick Sound Destroyer Mat Goal: 150 DB 149.9 Street Bass
subnoize Posted March 19, 2008 Report Posted March 19, 2008 4.00 cft net 38.00 square " of port area 16.00 inches of effective port length 9.50 square " of port area/cube 2.00 cubes/sub 34.23 hz i did not do the math but it sound right seen a lot of l7's in 2 cubes i am just suprized he's/you are tuning it for sql not spl of like 45 -47 hz but it what he wants not me
KICKERKX1200 Posted March 20, 2008 Author Report Posted March 20, 2008 so u think this will out preform the a box built to kickers specs of 3.67cf gross per sub? im not sure what its tuned to though, it doesent say on there site. also as far as tuning he wants deep bass not all out spl. thanks for the help
Team Sundown's Charles Posted March 20, 2008 Report Posted March 20, 2008 so u think this will out preform the a box built to kickers specs of 3.67cf gross per sub? im not sure what its tuned to though, it doesent say on there site. also as far as tuning he wants deep bass not all out spl. thanks for the help The spec from kicker are VentedCompact (Minimum Enclosure Volume)Pre Driver 1.75 ft3 (49.6L) + port displacement 2.5 x 13.25” (6.4x34cm) port, 22.5” (57cm) long Power Handling = 600W RMS Tuned 42HZ That would be 3.5ft3 + port displacement for 2 L7 VentedSPL/DeepBass (MaximumEnclosureVolume)Pre Driver 3.25 ft3 (92L) + port displacement 3 x 13.25” (7.6x34cm) port, 14.5” (37cm) long Power Handling = 600W RMS Tuned 38hz That would be 6.5ft3 + port displacement for 2 L7 I really couldn't tell you what would preform the best for you but you could build all of them and see with you like the best. The biggest thing is how much space you are working with and how much power you give them. 1993 Mazda Mx-3 Subs: 2 18" DC Audio Lvl 4 D.7 Highs amp: Sundown SAX-100.4 Sub amp: Sundown SAZ-3000D Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's Dampening: 120sqft 80Mil Thick Sound Destroyer Mat Goal: 150 DB 149.9 Street Bass
KICKERKX1200 Posted March 20, 2008 Author Report Posted March 20, 2008 no issues with space its a blow through and he is using a zx1000
Team Sundown's Charles Posted March 20, 2008 Report Posted March 20, 2008 no issues with space its a blow through and he is using a zx1000 Hes going to need more power then that. Each speaker is only going to get 250 wrms. He should have atless 2 ZX1000 or 1 ZX2500. They should have 500wrms each. 1993 Mazda Mx-3 Subs: 2 18" DC Audio Lvl 4 D.7 Highs amp: Sundown SAX-100.4 Sub amp: Sundown SAZ-3000D Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's Dampening: 120sqft 80Mil Thick Sound Destroyer Mat Goal: 150 DB 149.9 Street Bass
KICKERKX1200 Posted March 21, 2008 Author Report Posted March 21, 2008 birthsheet says 12?? watts. so subs will be seeing 500 to 600 each sub. this is plenty of power. not for SPL just a deep bass street beater
