Stephen13 Posted May 30, 2014 Report Posted May 30, 2014 Reading the Big 3 tutorial thread I see that it says to upgrade the following wires... - Positive from battery to positive from alternator- Negative from battery to ground- Engine block to ground My '11 Silverado has a factory 4AWG cable going from the battery's negative to the engine block. I've already added the wire from the battery's negative to ground. What point would there be in running another wire from the engine block to ground when it already has a direct path back to the battery's negative? 2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab "Enjoy yourself. It's later than you think."
Cj Kumz Posted May 30, 2014 Report Posted May 30, 2014 The more cables the more current flow. And since your stock cables are 4 gauge, you could do 1/0 gauge for the big 3. Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
Stephen13 Posted May 30, 2014 Author Report Posted May 30, 2014 I still don't see the need for it. 2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab "Enjoy yourself. It's later than you think."
Joshoe Posted May 30, 2014 Report Posted May 30, 2014 I still don't see the need for it. But still understand its ONLY 4 AWG wire for the ground..
Guest Posted May 30, 2014 Report Posted May 30, 2014 less resistance. literally why the big 3 is so important. decreases resistance, even if it is by a minute amount.
Stephen13 Posted May 30, 2014 Author Report Posted May 30, 2014 I get the lower resistance thing but the way I see it the resistance between the block to battery connection is going to be less than the resistance between the block to ground to battery connection. In my truck ('11 Silverado) the cable run from the block to battery is shorter than the run would be between the block to ground to battery. And as we all know current will follow the path of least resistance. So if all the cabling is the same AWG the least resistance between the block and battery will be found in the shortest run of wire. In my case that would be the block's direct connection to the battery making the block to ground cable run redundant, right? 2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab "Enjoy yourself. It's later than you think."
