Starting to get pissed... PLEASE HELP!
Is yout battery directly grounded with 1/0 to the alt? If not then thats your problem. Had the same problem. My shop didnt put my 1/0 run for neg to the battery and had major voltage problems. Seriously recheck your grounds for battery and alt before the belt. If there is black soot then its the belt slipping.
05 dodge magnum rt
DEH-80PRS
Rockford fosgate T600.4
st200 tweeters
Sundown Neo Pro 6.5 v2's
2 Saz-3500v2- Toolmaker dual 1/0 inputs
2 Sundown ZV4 12" D1
1/0 Sky High Power wire OFC
3 XS D3100- Toolmaker battery terminals
Mechman 320 Amp Alt
Smd Voltmeter
KnuKoncept 1/0 OFC
My magnum rpm was low (550) at idle and had to buy a diablosport intune to change it higher (set mine at 800). That also made all the difference. Might check to see if they have one for your car or even a superchip..
05 dodge magnum rt
DEH-80PRS
st200 tweeters
Mechman 320 Amp Alt
Smd Voltmeter
KnuKoncept 1/0 OFC
  • Who's Online   0 Members, 0 Anonymous, 1916 Guests (See full list)
