Daddy_ Posted May 31, 2014 Report Posted May 31, 2014 Just want to know whats the difference between Dual-Bandwidth Equalization and Programmable 24dB Active Crossover. Was looking at the chart on Audio control and needed help. Which processor do I need with he following equipment. 2 12" subs with 2 amps (1 per sub). 2 way component in the front, 3 way components in the rear with one amp to run the components. Chart is below in the link. http://www.audiocontrol.com/t34/5248/Trunk-Mount-Equalizers.html Will the LCQ1 and DQ-61 be fine? or is there another one thats better for my needs? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
AudioControlMT Posted June 2, 2014 Report Posted June 2, 2014 Hello Daddy_ The DQ-61 has 7 bands of EQ per channel (front, rear, sub) as well as an adjustable crossover. The EQ section is for boosting or cutting your signal at preset frequencies to achieve a balanced and relatively flat signal as the starting point to tuning your system. A crossover is used to filter your signal for highs and lows (DQ-61 does not have a crossover). The DQ-61 is our most powerful OEM integration processor at present Kind regards, 22410 70th Ave West Mountlake Terrace, WA 98043 USA P. (425) 775-8461 F. (425) 778-3166www.audiocontrol.com
