Enclosure Build: DirtyDonkey's Dual HD312's, birch, kerfed
Hey guys,
This will actually be a rebuild (redesigned too) of his last build because I let him down. I simply wasn't on my game, split up with my girl, wasn't in the right mind and let a sub-par enclosure leave my shop, but there's really no excuse...I screwed up and will be doing a rebuild that will exceed expectations.
I will be including videos along the way just with some thoughts on working with birch (and build tips in general) and how I go about things on a build like this (and more builds with vids like this to come).
I will also be taking a break from builds from customers (both wooferwarehouse.com and personal) for a while due to my work schedule, other projects that I want to work on, and more freedom with my time. 55+ work weeks plus enclosure builds adds up very quickly, some weeks over 75 hours of work and it takes it's toll.
Builds may still happen periodically shortly down the road but they will be way over the top as far as design + build go and I may auction them to give profits towards charities.
Anyways, onto the build...
Specs come to:
-3.925 cubic feet net
-31hz tuning
-42.25 sq inches of port area
Taping up the panel edges so I don't get chipping. The enclosure will be stained and lacquered once finished ;) so those edges must be perfect.
Vids, yes they're water-marked...oh well....
More when it happens...
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Team Tupperware
Team Tupperware
Ah yes, some stain for the haters...
Team Tupperware
2nd coat of stain...was going to really get some work done tonight but I think I have a migraine coming on, white orbs in my vision etc so I probably won't have more than this :/ Just hit these with stain and hit my bipod with some paint and may be calling it a night...
2nd coat's lookin good imo
Team Tupperware
Side panel with countersunk terminal cup added..*Note, this cup is just a crap-cup that I have laying around the shop for fitting, the real terminal cup will be gold twist-terminals of the same size*
Team Tupperware
Team Tupperware
Ofcourse PB cutoff the last 10 seconds of it, but you didn't miss much, thankfully.
Everything structurally finished and edges rounded-over :) Just need to get everything cleaned up and the staining and clearcoat will finish 'er off ;)
Team Tupperware
And, yes...I spray-glued carpet onto the underside of my jig saw before rough-cutting the cutouts...cant scuff them grainzzz...
Bit of an optical illusion on the top corner...idk, looks weird? lol
A little blotchy on the top, a 2nd coat of stain should help with that.
That grain....
Team Tupperware
More stain...
Team Tupperware
