luism1983 Posted June 9, 2014 Author Report Posted June 9, 2014 Ports are my weakness , that's why I usually just do a single sub set up easier to figure out Like this one I currently have audio fanatic
Triticum Agricolam Posted June 9, 2014 Report Posted June 9, 2014 A single 6" port would be a lot shorter and would fit well, but it would be too little port area and you would run into issues related to that. Two 5" ports is probably your best bet for using what you have built so far and should perform well. Just be sure to flare the ends of the ports well and you will be fine. 5" tubing is a little tougher to find, but its out there. Here is one place that has 5" cardboard tubes that would work very well for your application, the only probably is you have to buy a whole carton of 15: http://www.uline.com/BL_3704/Jumbo-Kraft-Tubes "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Cj Kumz Posted June 9, 2014 Report Posted June 9, 2014 Its not too late mate. Your subs need 2cubes minimum and you have about 2.8 cubes after displacing your subs. So you gat around 0.8 cubes to mess around with. You could just make external ports and you will be fine.. I do not have my pc with me to give you exact measure, but you could download torrez. It will help alot Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
Triticum Agricolam Posted June 9, 2014 Report Posted June 9, 2014 If you absolutely cannot get any 5" tubing three 4" ports will work, depending on how much power you are going to be putting into this thing. What are you going to use for an amp? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
luism1983 Posted June 9, 2014 Author Report Posted June 9, 2014 How long will the 4" ports have to be ? Since this is a family vehicle I cannot do external ports, or what if I do a square port ? Can that work? audio fanatic
Triticum Agricolam Posted June 9, 2014 Report Posted June 9, 2014 The 4" ports would need to be 29.5" long. If you wanted to do a square port I would have it fire out one of the sides, make it 5" high, the full 10" interior width and 26" in total length. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Cj Kumz Posted June 9, 2014 Report Posted June 9, 2014 Square ports normally chew more space than round ports, and in your case space is already limited. I think go with what Triticum says. The round ports should get slightly above a cube of space, so you will be still above the minimum volume. You still didn't say what power you will run them off? Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
luism1983 Posted June 9, 2014 Author Report Posted June 9, 2014 For now I am just using one t1500-1bd just to see how they sound , but planning on getting a second amp audio fanatic
luism1983 Posted June 9, 2014 Author Report Posted June 9, 2014 The only problem with the ports in the side is that the wheel wells are on the way and if I put them higher they will block the window audio fanatic
Triticum Agricolam Posted June 9, 2014 Report Posted June 9, 2014 Well if you have to port out the back you will just have to put some 90 degree corners in your ports, which is less than ideal, but when it comes to subwoofer enclosure design something always ends up being less than ideal :-) "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
